I asked ChatGPT 03 and below is the answer I received. Does this sound correct? Asking because I'm adding a cooler and trying to determine if a push lock hose with a max temp of 257°F is sufficient. I'm guessing that it's okay, because I'd have other issues before getting to that temperature.
Typical temperatures when rock‑crawling
| Operating context | Common fluid temp | What’s going on |
| Normal on‑road driving | 150 – 180 °F (65 – 82 °C) | Moderate steering effort plus good vehicle speed keeps the return‑line cooler supplied with airflow. Pirate4x4IH8MUD Forum |
| Slow technical off‑road/rock crawling | ≈ 200 – 240 °F (93 – 116 °C) sustained, with brief spikes up to ≈ 250 °F | Very high steering load at idle/low rpm and almost no ram‑air through the factory “paper‑clip” cooler lets heat soak quickly. Pirate4x4JL Wrangler Forums |
| Warning / damage zone | > 250 °F (> 121 °C) | Fluid oxidation accelerates, seals harden, pumps cavitate and may “puke” fluid through the cap; many OEM systems will trigger a steering‑temp warning light around this point. Pirate4x4Grassroots Motorsports |
Rule of thumb for trail rigs: keep the fluid under ~220 °F whenever you can; treat anything over ~240 °F as a sign you need more cooling or higher‑spec fluid.
