STICKY How-to Index
hear
Can't type
Lifetime Supporting Member
Prosper, TX
Axles/Differentials
Re-gearing Axles
Body/Doors/Exterior
Brakes
Cooling
Electrical
Engine/Sensors/Underhood Stuff
Frame
Fuel System
Hard top/Soft top
HVAC
Interior
Lifts/Tires
Lighting
PCM Related
Seats
Sound System
Steering/Suspension
Transfer Case
Transmission
Wheeling Odds & Ends
Odds & Ends
EDIT: apparently there is a 50,000 character limit per post, and we hit it around the time I categorized the final pages.
cc: @Chris
I've been kind annoyed by how hard it is to find specific how-to guides on our little forum. We have some great content, but I find it hard to search, even using google. Maybe your google fu is stronger than mine, IDK. But w/o too much effort I extracted the links from the how-to subforum and attempted to classify them. My thinking was that it is easier to do a quick visual scan in a labeled subsection or a ctrl-F to find a specific word. Maybe I'm the only one who thinks so, I guess we'll see. At this point we don't get that much new content here so maintaining this shouldn't be super hard.
If you disagree with the classification of a topic, I can move it. Lots of topics span multiple categories, so I tried to go with the primary topic. Case in point is the guide on the 4WD light. Is that transfer case, electrical, lighting, or interior? I went with lighting, because I had to pick something. There are a bunch of others that weren't immediately obvious how to categorize, so I stuck them in the drunk drawer, confident that y'all would come out of the woodwork to tell me where they should be classified.
Anyway, I hope this helps. I know it will help me. And maybe it will save people from making duplicate how-to's. You probably didn't realize how many of those we had.
Enjoy, flame away.
cc: @Chris
I've been kind annoyed by how hard it is to find specific how-to guides on our little forum. We have some great content, but I find it hard to search, even using google. Maybe your google fu is stronger than mine, IDK. But w/o too much effort I extracted the links from the how-to subforum and attempted to classify them. My thinking was that it is easier to do a quick visual scan in a labeled subsection or a ctrl-F to find a specific word. Maybe I'm the only one who thinks so, I guess we'll see. At this point we don't get that much new content here so maintaining this shouldn't be super hard. I think I'm through page 8, with 3 pages to go to have them all moved into this index, so if you see something missing from page 11, that's why.
Enjoy, flame away.
Thanks so much for doing this!
  • Love
Reactions: hear
Man, I owe you a beer, @hear! Job well done! How long did this take you?
Honestly, not all that long. A better man would've written some code to scrape the links from the page, but I didn't consider that until after I had already categorized about 3 pages. It maybe took me 5-10 min/page to copy the link, paste it in another doc & categorize it. The python to convert them to bulleted links was near zero effort. Because I spent zero effort on the python, I had to manually paste each category into PyCharm and then run my script, then paste the output into the post draft. I got a pretty good flow going and did that in probably 30 minutes or so.
All told, I have a couple of hours invested, not including the time spent convincing you this was a good idea. :p
I lied. It took me 16 minutes to rebuild the index from scratch. There's an xkcd comic about the ROI on automation, where it gives a grid of how long it takes to automate something vs how much time you save by automating x how often it needs to run. I'm still well into the positive ROI for the time being.
Also, @Chris I found these threads that somehow survived peer-review. There may be a couple of others that made it into the index before I decided to categorize these. I fully expect to crowd source the remaining quality/categorization issues.
https://wranglertjforum.com/threads/bank-1-lean-code-help.35500/
https://wranglertjforum.com/threads...o-i-need-to-run-these-wheels-and-tires.34374/
https://wranglertjforum.com/threads/help-with-gear-mesh-contact-pattern.33765/
https://wranglertjforum.com/threads/97-tj-stalls-when-giving-it-gas.33074/
https://wranglertjforum.com/threads/will-a-4-0-from-a-98-tj-work-in-my-2004-with-a-2-4.31732/
https://wranglertjforum.com/threads/2004.28129/
Another lost jeeper:
Reactions: SSTJ and Chris
And since I'll probably wonder how I did this, or if somebody else wants to do better....
Python:
import csv
with open('scratch_1.txt') as file:
    csv_reader = csv.reader(file)
    print('[list]')
    for link in csv_reader:
        l = link[0]
        # the BBcode link needs the wranglertjforum domain prefix
        addr = l.replace('https://', '')
        # hygiene the human readable link
        s = l.replace('https://wranglertjforum.com/threads/', '')
        s = s.replace('-', ' ')
        s = s[:s.rfind('.')]
        print(f'[*][url="{addr}"]{s}[/url]')
    print('[/list]')
Okay, I thought you had sat there and done this all by long process copy and paste. I was pretty taken aback. Now it makes more sense!
ha, no way. I only thought it would be a good idea because I could do it in a minimal amount of time. I might write a lambda function that looks for new links and alerts me when a new one shows up. I could probably programmatically add it to the index but I'm not interested enough to figure out the nuance of how.
In any case, I appreciate it. It certainly does add organization to the forum which I am very big on.
  • USA Proud
Reactions: hear
