The Warn PowerPlant is kind of an odd duck. It's a combination winch and air compressor, with the compressor driven by the winch motor. Warn released two models around 2007 (and updated them in 2013), a 9,500 lb. version and a 12,000 lb. version. The two models differ mainly in the planetary gearing, with lower gearing providing the extra pulling power for the 12,000 lb. model at a lower line speed.
Underneath the aluminum cover, the body of the winch has some similarities to the M8000 and 9.5 Ti winches and does share a few parts with these models. But the air compressor and housing are unique, and there are many parts that are specific to the PowerPlant models.
It's kind of a heavy winch, but swapping in a synthetic rope makes it lighter. The air compressor puts out 5 CFM at 90 PSI which airs up big tires pretty quickly and could possibly be used to run small air tools (but nothing like an impact wrench). Some people might say this winch makes a better boat anchor, but I happen to like mine.
Unfortunately, Warn discontinued the PowerPlant models and doesn't provide service for them anymore. Fortunately (as of 2020), both Redding Four Wheel Drive (https://www.winchserviceparts.com/) and Montana Jack's (https://www.montanajacks.com/) still sell service parts for these winches.
One potential problem with this winch is that with enough wear and use, the compressor piston head can separate and jam in the cylinder, breaking the piston shaft. That happened to me recently.
In these winches, the mode switch will disconnect the drum when you're running the air compressor, but the compressor piston has a direct connection to the motor, so it runs even when you're just using the winch. That means that a busted compressor also takes your winch out of service.
I broke down the winch to identify parts that needed replacement, ordered the parts, and repaired the compressor. I figure that since these are unusual winches and there's not much support for them, a how-to might be useful for someone.
