Sony XAV-XA3200 Head Unit Install
AndyA
2006 TJ X
Tucson, AZ
This is how I installed my new head unit with front and rear cameras, microphone, USB connector and satellite radio. I chose this unit for the following reasons:
- double DIN
- doesn't require hacking parts out of the dashboard
- fast bootup time and responsive screen
- Apple CarPlay
- Satellite radio
- Front and rear camera support
- Physical buttons
Complete shopping list:
- https://www.crutchfield.com/product/item/default.aspx?i=158XAV3200
- https://www.crutchfield.com/product/item/default.aspx?i=220SXV300
- https://www.crutchfield.com/product/item/default.aspx?i=249CUB01 x2
- https://www.crutchfield.com/product/item/default.aspx?i=120ISOPK
- https://www.crutchfield.com/product/item/default.aspx?i=120956541
- https://www.crutchfield.com/product/item/default.aspx?i=120706502
- https://www.crutchfield.com/product/item/default.aspx?i=12040CR10
- https://www.amazon.com/dp/B08VJL2K5S/?tag=wranglerorg-20
- https://www.amazon.com/dp/B01NCA9XEI/?tag=wranglerorg-20
Here is how it looked at the beginning.
The wiring from the vehicle harness to the Sony unit was easy because the Sony and the Metra pigtail use almost the same wire colors (some kind of industry standard?). I wired the parking brake to ground. The reverse wire I connected to pin 33 of C300 (white with light green hash). Because that wire has to snake from the center of the dash to the driver's side outer footwell I used an inline spade connector so it can be disconnected.
Next I drilled a hole into the blank panel near the switches. On the back of the panel there is a marking in the mold to indicate where a circular connector goes (switch to turn passenger airbag off I believe) so I used that as a guide, drilling a hole and then using a Dremel to enlarge it.
The microphone is designed to clip onto a visor but I didn't want any wires showing so I converted it to panel mount and installed it at the driver's end of the defrost vent panel.
I put an M12 external circlip into the first groove in the mic and 3D printed a cover. I epoxied the cover onto the circlip to hide it.
After drilling a hole through the defrost vent cover I installed a 4mm thick 3D printed washer and then another M12 circlip. I think this makes it look nice and tidy and discreet.
The satellite radio antenna was the easiest part. I shoved it under the cover of the rail that goes across the back holding the speaker pods. I chose this location because according to the Factory Service Manual this is the factory location for it.
I 3D printed a mount for the front camera which bolted onto two spare holes in front of the AC condenser. I ran the wire around the driver's side outside edge of the engine bay, through the firewall and grounded it at a point a PO had created.
Power for the camera was tapped from the Run/Accessory wire going to the radio.
The yellow RCA connector plugs into the RCA to 3.5mm plug adapter however the Amazon listing for the adapter shows the wrong pinout and I had to plug the yellow connector from the camera into the white connector on the adapter (sigh). The important thing is that the ground is in the correct location on the 3.5mm plug.
The front camera is tilted down so I can see part of the front bumper.
For the rear camera I 3D printed a bracket to go behind the driver's side tail lamp. I originally experimented with putting it poking out of the spare tire but I wasn't happy with the sturdiness or the wiring routing so I changed to this. It's not ideal because it is so far from the center of the rear but it works OK. The printed part has a channel for the wire to run down, keeping it hidden as much as possible.
Originally I tapped power for the camera from the reverse wire going to the tail light, however that was not workable.
The Sony unit has an option to view the reverse camera at any time and also the guidelines could only be configured with the camera powered but the vehicle not in reverse. In the end I changed it to being powered from the same Run/Accessory wire as the front camera.
The Sony unit is double DIN but actually only takes up a single DIN space. The problem is the Metra mounting brackets. Rather than cut up the dash I cut up the brackets.
Here is the final mess of wires:
And here is the result.
I then added a custom wallpaper generated by the MidJourney AI.
Andy
Here are the 3D printed files and the hardware needed. All printed in PETG. The front camera mount was printed with 60% density.
Front camera mount hardware:
- 1x #10x5" bolt, phillips pan head
- 1x #10 nyloc nut
- 2x M6x50 hex head bolt
- 2x M6 nyloc nut
- 4x M6 washer
Microphone mount hardware:
- 2x M12 external circlip
Andy
  • Rear Camera Mount 3.stl
  • Mic - Washer.stl
  • Mic - Cover.stl
  • Front Camera Mount 2.stl
  • Front - Bolt Mount 2 Right.stl
  • Front - Bolt Mount 2 Left.stl
This is pretty sweet. Has been on my to do list for both of my vehicles for awhile. Thanks for details.
The camera mounts are sweet. That’s been hiccup on why I haven’t done this yet
Reactions: AndyA
I thought that head unit only supported one camera unit, how are you able to have front and backup cameras? Or are you only capable of one of them as I’m lead to believe?
It has support for a backup camera and a video source. Andy
Can you post a photo of the rear camera view based on your mounting position? I’m extremely interested do this mod!
I am out of town for an indeterminate period so I don't have access to the Jeep.
It's not a great view but it gets the job done. I wasn't able to align the reversing box thingy to reality, which was a bit annoying. It wouldn't go low enough on the display and seems it is designed for lower mounting points than I used.
Andy
Gotcha, I was thinking about mounting mine in the rear bumper above my trailer hitch. How does the sunlight effect the screen?
I got mine installed, just haven’t picked cameras for it yet as I’m still trying to figure out a mounting location for the camera.
- double DIN
- Apple CarPlay
- Satellite radio
- Physical buttons
Andy
Outstanding job. I just installed that reciever-
Questions- is there a way to turn on the rear view camera “on demand” when its wired to trigger from the reverse signal?
Also, any easy way to stream video ?
I found you can shim out the climate control module to fit the bezel better pretty easy,
Again, great, thorough work Andy.
Signed,
Andy
Reactions: AndyA
Signed,
Andy
Hi Andy,
Tap into connector C300 pin 33, white with light green hash. That is the reverse signal. Connect that to the receiver.
To stream video there are RCA connectors on the back. I hooked them up to a front camera but you could use any source.
Regards,
Andy
Hi Andy,
Regards,
Andy
OK I may be getting a little lost- Currently I have my rearview camera wired to the camera wire coming from the receiver- So it works when I put it in reverse
I’m trying to follow what you’re telling me to do- To get the ability to override that but I guess the nomenclature kind of loses me a little bit also
Sorry I completely misunderstood.
What you could do is wire a toggle switch into the wire you have tapped from C300. When it is the first position the C300 wire is connected to the receiver. When it is in the second position the necessary voltage (12V? 0V? IDK) is wired to the receiver. The toggle switch could be mounted under the driver's kick panel. I haven't tried it though.
Andy
Andy
Thanks man
Andy
Just checking to see how y’all like the radio and if there are any issues.
I have an 06 LJR and don’t want to cut up the subdash and this looks to fit the bill.
Let me know if running CarPlay and if it’s G2G on this unit.
Many thanks for posting all the install info.!!!!
Thx
Dave
Love the unit
Carplay is great
Installs with no cutting or drama
It is a simple no frills unit, mine is set up to stream video and works really good for it.
