Many of us find ourselves at sketchy crossings wishing we had a snorkel, or don't like the looks or sound of a safari snorkel. I have had water flush with the top of my fenders and had some water get into the airbox a few times, but not enough to get in the intake. This is a simple no drill temporary snorkel that is easy to put on and take off.
In no way is it watertight, it is only meant to be a bit of insurance for short crossings. If you wanted it to be watertight you would need to plug the airbox drains, silicone the adapter, grease the airbox lid, as well as raise the breather lines, and dielectric grease every connector. By then you could just buy an actual snorkel. Also, many would say that the 2.5" PVC is restricting, and the 10' long ribbed hose is too, they are correct. This may squeeze a few of the little tractor horsepowers you have. Oh, and don't drive with this on the highway.
Before you start, if you wanted an even simpler and faster snorkel you could just do a little bit of trimming and slide a 3" vacuum hose over the factory air horn and then clamp it down.
You will need a few tools available in any garage and a few parts from any local home improvement store.
Tools:
Handsaw
Parts:
10' Long 3" I.D. Pool/Vacuum Hose (15-20' would be better but not required)
At most 1' of 2-1/2" Schedule 40 PVC/Conduit (Used for swimming pools and electrical)
2-1/2" Conduit PVC Male Terminal Adapter (Found at Home Depot)
2-1/2" Conduit Locknut
3" Hose Clamp
Step 1
"Roughly" cut terminal adapter until there is 1 in. from the flange. Cut around 2" of 2.5" PVC and insert it into the terminal adapter. (May require a few taps from a hammer.) You can also glue the PVC together, but it is a snug fit. Take my measurements with a grain of salt and measure it all yourself.
Finished Product (Don't mind the poor quality cut and roughed up terminal adapter)
Step 2
Remove the factory air horn by turning it, insert the adapter into the airbox and make sure it fits over any a/c lines. I put some small washers under the airbox to get more room. Snake the vacuum hose through the engine bay avoiding belts, hot things, and fans to wherever you want to go. Remove the adapter and put the vacuum hose over it with a hose clamp.
Step 3 (Profit?)
With it pre-assembled, finagle the adapter into the airbox where the air horn was and put the locknut on the adapter. I put the locknut on backward so it would self-center with the bevel. You may need to cut out some little tabs in the bottom of the airbox to get it on perfect. You could also make a plate out of plastic so it would seal and fit better. I would not recommend using any permeant silicone on the adapter and airbox but any removable silicone could be applied around the adapter. The adapter is slightly less restricting than the factory air horn and could be kept on as a splash guard without the snorkel.
I ran the hose above the PCV line and just over the frame behind the fender.
From there you can attach it to your mirror. you could also use a longer hose and run it anywhere, such as in the cab or the roll bar.
Tools:
Handsaw
Parts:
3" Hose Clamp
Step 1
Step 2
Step 3 (Profit?)
