2000 Jeep TJ Sahara 4.0L, stock front axle and I believe stock control arms.
I’m in the middle of replacing all four front control arms. Everything was going smoothly until I got to the passenger-side lower control arm mount on the axle. The bracket/housing is bent badly enough that the bolt will not come out, and it’s clear the new control arm will not fit correctly either.
(Photos attached — passenger side first, driver side second for comparison.)
At this point I’m looking for advice on:
The axle is already removed from the Jeep, so I can easily drop it off anywhere around the Cleveland, Ohio area.
Dealerships don’t seem interested in touching it, and I’m still waiting to hear back from a few local shops.
Any recommendations or advice would be appreciated.
Thanks,
- Best way to remove the stuck control arm/bolt
- Whether this bracket can realistically be straightened
- Or if the mount should be cut off and replaced
Thanks,
