STICKY Jeep Wrangler TJ Factory Service Manuals (FSM) & Technical Documentation
New to this, but does anyone know how dramatically different the manual for an RHD and an LFD Jeep would be? Having some electrical issues with my 2005 RHD, and I could really use some help.
There are RHD annotations within the FSM whenever variations occur.
The Factory Service Manual covers both (I don't think there is a separate manual for RHD vehicles), but it doesn't usually show separate pictures for the RHD. Example:
However, in some cases (probably when absolutely necessary), it notes a different drawing or different procedure for RHD vehicles. Example:
More specifically to your question, the wiring section (8W) notes differences on the schematics for RHD vehicles:
And in the connector pin-outs, when there is a difference, they show the LHD and RHD functions for each pin. For example, here's the pin-out for the heater control C2 connector shown above, where connector pin 1 differs for LHD and RHD (pin 3 does, too, but I didn't circle it below):
Finally, separate connector location diagrams are shown for some assemblies that are completely different, like the dash below:
As for the Factory Parts Catalog, it covers both, too, and it does that by showing separate diagrams for RHD assemblies when needed, as well as a "U" designator in the Line Column:
I hope that helps! Just download the manuals and search for "RHD" to see how they are arranged for RHD vehicles.
Reactions: Reign Mack
hear beat me to it while I was writing my typically over-detailed response. :ROFLMAO:
Reactions: hear
I was wondering if anyone has the wiring diagram for the hvac system non a/c? Mine looks like most abused 2000 tj's. Im trying to restore one and I can't figure out the colour codes that I have got. Any help would be massive.
Is it not in the diagram for the 2000? There won't be a separate diagram, just provisions for different options inline with the diagrams, such as non-a/c.
This post is for TJ documentation like Factory Service Manuals Etc..
A while back I was able to find the FSM for my 2006 TJ. I decided to look at the same website I have used to download FMS to see if I can find others. I hit the jackpot so I am sharing :beer-toast1:
Please if there are any issues or they are inaccurate let me know.
Thanks @UpperMI for the additional 2002 manuals
Thanks V
Reactions: JeepNWilly
If anyone has any additional manuals let me know so I can add them to the main post.
I am looking for the 6 Speed NSG370 Transmission.
I have the same Jeep in a Rubicon. From what I've read, an AX15 would be a better swap, if you can find one. Dodge Dakotas in the late '90's had AX15's, but they had different I/O shafts because they didn't use AMC engines and the same T/C's. Still trying to see whether the swap parts are available.
Did you know that you were replying to a nine-year-old post? Also, the way I interpret JeepNWilly's post, he was not looking for a transmission. He was looking for a service manual for a transmission which, incidentally, is incorporated into the FSM.
Correct back then I was looking for the manual which eventually I found and added it to the post.
I actually found a NSG370 week ago. Going to be putting it in my Jeep at some point and rebuilding my original NSG370 since it has gotten really bad overthe years. Will see how that goes.
Reactions: Alphonse53 and sab
I knew all that except he had posted the manual after the fact. See his lasted reply FYI.
  • Face Palm
Reactions: sab
I agree, let's do that:
The fact that he eventually needed a new transmission doesn't change the fact that he was seeking a service manual, not a transmission, nine years ago. Context is important, especially since this thread is a resource thread, not a transmission repair thread. Many threads on here wander, and I actually like that about this place. However, not in a topic-specific resource thread. That's why I commented.
However, if it's more important for one of us to be right then, you're right, and I'm wrong. It's not worth arguing about. I'd rather keep this thread clean than be the "winner."
Nice ninja edit. You're gonna do great here.
To bring it back on topic, does the document sort order bug anybody else?
A little. It could certainly be better. However, as a 2005 TJ owner, this bugs me much more because there's no way to know what those three documents are without opening each one:
we could probably change the names to YY - <doc type>.pdf
YYYY is unncessary, and the "Jeep Wrangler" is implied. Or maybe just Jeep TJ, which might help SEO & LLMs.
Thank you! Appreciate you thinking of others...
