Tire Road-Repair Options
TJMexico
NW Mexico
I always travel with repair options for tire punctures in addition to a spare. Can't be over-prepared where I wander.
Traditional string-type plugs have always worked, though they are sometimes a bit difficult to get in the hole. I just ran across some threaded type plugs that I do not remember ever seeing before and have certainly never used. I'm wondering if anyone has any experience with them and if they are worth having on-board. They go in with a bit of lubricant/adhesive and a phillips screwdriver.
I am thinking that if they work, they would be perfect in a pressure situation, like a rainstorm or late at night in an area where I would not want to be hanging around any longer than necessary. (There are places like that where I travel.) Also, they might be a better option for a very small puncture.
Here's a picture of them:
Here'a an Amazon link to one of the versions of the product.
So, has anyone used them? Do they work? Should I just stick with the string-type plugs?
Also, what about sidewall repair slugs? Anybody used one of those on a sidewall puncture or cut?
Just an anecdote: I have a friend who used to live in Paraguay, in an area called The Chaco. It is affectionately referred to by locals as El Infierno Verde (The Green Hell), and that is not an exageration! Between flora and fauna, the place will eat you alive. 10" dust in the dry season, 12" mud in the rainy season. Everything there either has big thorns or big teeth.
There are little ranches and villages scattered throughout this inverted paradise and people are very hospitable. My buddy carried TWO spares in his truck. We had a puncture on one outing, stopped and changed the tire, and then stopped at the next ranch to patch it. There, we were treated to typical country-folk hospitality, given refreshing drinks and rest in the shade while my buddy fixed his tire. His truck had split rims and he ran tubed tires; he would either patch the tube or replace it, so he had to manually brake the tire down.
He told me that nobody traversed that place with less than two spares as big thorns abounded and getting caught without wheels could actually mean death!
Maybe that experience is why I am a bit anal about having backup for my tires.
Reactions: Zorba and ColoJeep
Ive used the ARB tire plug with great success. I was able to plug sedan and SUV tires for thousands of miles. The supplied tools arent the greatest, but im sure they would work in a pinch
https://www.amazon.com/dp/B075CR4J3W?tag=wranglerorg-20
Right. That is what I typically carry, and what I would have most confidence in. I have repaired my tires and tires of others on the road with those.
The screw-in type plugs - if folks generally recommend them as decent and trustworthy - would be more of an emergency back up for, as I said, if I am caught in a rainstorm or some situation where I need to move on in a hurry. Just another option, if they are worth having.
The sidewall repair would have saved me some heartache once when I cut a sidewall hotdogging around a tight turn between a descent and an ascent. My buddy recommended that I back up and turn, but I decided to just cut the wheel and gas is. I got around the turn and up the hill, but I hit a rock in the turn.
I have used the sticky plugs for years with good results, but I have to remove the tire to get the right angle and leverage to force the tool and plug into the puncture hole.
I have often wondered if the Dynaplug would be easier to insert as they have a pointed metal tip.
https://www.amazon.com/s?k=dynaplug+tubeless+repair+kit&i=automotive&crid=6ULREPB7GMPD&sprefix=dynaplug,automotive,491&ref=nb_sb_ss_p13n-expert-pd-ops-ranker_1_8&tag=wranglerorg-20
Back in mid-May, I got a flat on my motorcycle. It was caused by a drywall screw. I tried a Dynaplug, but it was too small of diameter. I didn't think to try several in the same hole. A simple string plug did the trick. I put another 800 miles on that tire without loosing any pressure. It's still holding today because I have gotten around to installing the replacement tire.
Reactions: bbaldwin237
I haven't tried the screw in plugs, hopefully you will try them and give us a review!
I have had success with a Slime kit, but then I rarely have flats. After reading about the Nealy kit I decided to buy a couple and I carry one in my Jeep and one in my RV but have not had the occasion to use one yet and hope I never do.
https://www.nealeytirerepairkit.com/
I've never seen these before , I would hope the reality is as good as the the idea . If you try these out , please report back .
Reactions: TJMexico
Back in mis-May, I got a flat on my motorcycle. It was caused by a drywall screw. I tried a Dynaplug, but it was too small of diameter. I didn't think to try several in the same hole. A simple string plug did the trick. I put another 800 miles on that tire without loosing any pressure. It's still holding today because I have gotten around to installing the replacement tire.
I saw the Dynaplugs were smaller diameter. Wasn’t sure if that mattered or not seeing how difficult it is to get a regular sticky plug inserted.
I can attest to the durability of the sticky plugs. Back in school I put one in the rear tire and it held air even after smoking the tread completely off the rear tires. The plug was quite visible on that “drag slick”.
Yeah, I've used the sticky string plugs extensively and never have put a patch behind them. Only thing I don't like is that if the hole is tiny, you have to make it bigger. That's one thing that makes these screw plugs look interesting.
I guess I'll have to order a set of those screw plugs and be the guinea pig. My TJ has a very slow leak on a rear tire right now, so slow that I haven't even bothered to fix it, just top it off every couple of days. Maybe I'll order a kit and try it out on that hole.
Reactions: ColoJeep
Safety seal and Glue tread. Safety seal 10/10. Glue tread 6/10.
I have ordered a lot of those little screw plugs. They will be in on Monday.
As I mentioned, a rear tire on my TJ has a sloooooooow leak that I simply have not bothered to patch. I'll try one on that hole. Expect a review in the next couple of weeks.
I hope it doesn't screw up my tire. I read that if they don't work, they are pretty much impossible to remove; but reviews are generally very good.
Reactions: ColoJeep
I've used Safety Seal brand string plugs 25 yrs with great success. I carry both their standard as well as "slim" sizes in all my vehicles.
I did not know there were slim gooey plugs. My insertion tool is what makes inserting the plugs difficult as the eye is typically much larger than the hole in the tire. That's where I thought the Dynaplug might work better.
A buddy of mine has worked in the tire repair business for at least 30 years. They used to fix everything for us from standard road tires to deer antlers in tractor tires and tee posts in atv tires. I asked him what kit to buy and he said it's no question get the safety seal plugs.
Ran an ATV tire for years with plugs filling a 3/4" to 1" diameter hole with no issues.
Reactions: ColoJeep
Agreed - use as many S-S string plugs as necessary to do the job, depending on puncture size and shape. Once holding pressure, I haven't had subsequent leakage or failures. A few examples;; one string on SxS (32" Maxxis Carnivore) and 2 strings on 2017 JK Rubicon (OEM 32" BFG KM1).
Just did it! Have a look at part 1, the application. I'll do another once I've ridden it for a couple of weeks.
Reactions: ColoJeep
