If you have a costco, I've had good luck with this hose for a couple of years.
https://www.costco.com/p/-/flexon-5...e-with-guard-grip/4000267125?sp=lws&langId=-1
We have 3 things that kill garden hoses. Heat, high water pressure and forgetfulness.
We have 3 things that kill garden hoses. Heat, high water pressure and forgetfulness. In the past, if we forgot and left the hose bib on, the heat and pressure would ruin a hose in short order. I grew weary of buying Home Depot grade overly expensive junk and purchased a couple Dramm Colorstorm in both 5/8" and 3/4". I now own 6 for various uses and leave them on 24/7 in the summer with zero issues or failures and have for several years.
When I bought the first one, I likely would have purchased the Gempler version since it now higher heat and pressure rated.
https://gemplers.com/products/dramm...toYxUc7aa2bnq760OoCh10J0okX_9moSUUe_CilaHeHfr
Depends on the repair fitting and then how the hose is constructed. The cheaper hose actually have a rib inside them that has to be trimmed out or they will leak and you can't get the repair fitting inserted easily. Then you have the mess and hassle of dealing with whatever clamp you've chosen and it happens to be right where you need to grab the hose to remove and install it or any of various nozzles.why not just repair the end that busted?
Eley
https://www.eleyhosereels.com/collections/garden-hoses
Also the hose reels and nozzles are the absolute best, but you pay for them. I bought two reels with hoses and nozzles a few years ago and do not regret the purchase one bit. They do not restrict flow at all.
I can't speak to the quality of the Gempler option but I do know they carry a lot of good stuff. If you do go with the Dramm option, once you get it, you'll wonder why you ever messed with crappy stuff.Thanks for this. The amount of hoses we've gone through is astounding. I've been looking for something that would last a long time.
