The wire goes behind the dashboard.
The top can be unplugged just like a fuse.
A photograph would go a long way, not much to go on otherwise. Lots of wires behind the dash.![]()
It's a type of immobilizer. Pull the clip portion and it won't start
weirdly didnt upload initially. Can u see it now?
And here that someone is.![]()
Who has a hardwired plug specifically for heated clothing? This is a time when I don't fear AI taking over.Claude seems to think it's most likely a battery maintainer. But I want to learn more about 12V heated clothing.
This appears to be a 2-pin accessory power connector, most commonly used as the cabin-side connector for one of the following aftermarket accessories:
- Battery maintainer / trickle charger (most likely)
- 12V heated clothing (Gerbing/Warm & Safe style)
- 12V air compressor or portable accessory power
- Less commonly, an old CB radio or other removable accessory.
Follow the cable:
- If it goes directly to the battery (possibly through an inline fuse): it's almost certainly for a battery maintainer or general 12V power.
- If it goes through a relay or switch: it may have powered an accessory.
- If it disappears toward the firewall and then to the front bumper/grille: it could have been for a block heater or external charger connection that someone relocated.
It is and not one of good ones. It is one of those that the dealers pay 50 bucks installed and then try to collect 500 from the buyer for.It's a type of immobilizer. Pull the clip portion and it won't start
