I found one in the woods today.
View attachment 710671View attachment 710672View attachment 710684
Tree-50 powered. I'll see myself out. :sneaky:
The body tag seems to suggest a 1948 "Stylemaster Sport Coupe".
Body production number 810.
Trim code "150" was "Gray Striped Pile Fabric" for the interior.
Paint code "379" was "Battleship Gray Metallic" upper over a "Dove Gray Metallic" lower.
View attachment 710677View attachment 710680
https://chevy.oldcarmanualproject.com/models/index.htm
So it probably look similar to this one.
View attachment 710681View attachment 710682
In black for fun
They have battleships with metallic paint!?
Cool.
Reactions: BlueC
Cool.
Part of a good Razzle Dazzle paint scheme. ;)
This one has a little too much Razzle...
And unless they're trying to hide in Key West, this one has way too much Dazzle. :sneaky:
I want a mountain motor, and I don't care what it's attached to.
View: https://youtu.be/4Fg_tPIab3o?si=_hnGBz7B_2b3XLUL
For those that don't know, "mountain motors" are a class of pro stock racing that run big cubic inch motors, up to 840 ci, just a smidge bigger than the super charged 500 ci babies of the other classes. Mountain motors are n/a running on gas with compression ratios around 17-18:1. They make the kind of sounds that tickle when you're nearby. ;) I can't help but wonder what 800+ ci could do with meth and a blower. :unsure:
Sonny Leonard has an out-of-class engine for sale...
View: %5BURL%5D%5BURL%5Dhttps://youtu.be/4Fg_tPIab3o?si=_hnGBz7B_2b3XLUL[/URL][/URL]
Don't know if you watch cleetus ever, but one of his guys "Jackstand Jimmy" has a catfish Camaro that he's putting a 903 ci Pat Mosi engine in. Link below should start at the right time, if not it starts about 13 minutes in
View: %5BURL%5Dhttps://youtu.be/6_quJlgCSC0?t=808[/URL]
"Bought it, it didn't quite fit." :LOL:
I check in with the Clettus crew here and there. Do you know what his plans are for it? 903 ci takes him out of the NHRA "Mountain Motor" class.
I watch most of the Cleetus stuff but I haven’t followed Jackstand’s build. The place where I’ve seen it discussed the most is over on CJ race cars YouTube but to follow it you have to watch multiple different topics so I don’t watch it.
How many feet of dragstrip is one of those rated before teardown?
Years ago I was told a good pro stock engine would generally last a season, but had a lot of top end maintenance throughout the season. I think I was told the valvetrain only last about 10 passes before the heads are pulled and swapped or rebuilt. The last I heard, probably 10 years ago now, annual rebuilding for a competitive pro stock engine cost about $50-60K (assuming no major damage). With inflation since then I'd guess that cost is closer to $100K now.
Reactions: Rickyd and reddvltj
