ohiopatriot
Did you notice a small 'knocking' noise coming from the right rear ? haha
You know that rotational clicking noise you normally get with a rock in your tread? Yeah, this sounded nothing like that.
Well done...time for a well deserved cold one..:beer-toast1:Changes out the tie rod at the pitman arm.
Installed new bushings in my front Currie trac bar.
Changed all the fluid.
Enough forvtoday.
I put in a new idle air control valve to see if it will solve the idle problem. It settles down slowly sometimes. The old one looked as though it may have been worn.
Seems to have improved so far, time will tell.
1997 TJ SE 2.5, 194,000 miles.
Pretty sure it was the original IACV, I kept it just in case.
I also installed new Mopar mirrors, nice improvement, they stay in place for a change, the old ones jumped around (original equipment, worn out, corroded.)
Removed OME transfer case lowering kit and installed Brown Dog 1" Motor Mounts. I should have done this from the start. Installing the new motor mounts were not trouble at all. Even moving the radiator shroud was easy. Big improvement in looks, and even the way it drives. Much more responsive to throttle with the new mounts.
Also removed a rusted upper sway bar flag nut..
Love your wheels! May I ask what kind?Removed OME transfer case lowering kit and installed Brown Dog 1" Motor Mounts. I should have done this from the start. Installing the new motor mounts were not trouble at all. Even moving the radiator shroud was easy. Big improvement in looks, and even the way it drives. Much more responsive to throttle with the new mounts.
Thanks. They are DX4 7SLove your wheels! May I ask what kind?
A couple of odd jobs and loose todo's to get her up for sale, as well as cleaning her up good. Bittersweet
You found a replacement @tomtaylz ?
Front Bumper as requested ...It was polished steel...but I felt it was too much bling so painted the bumper black about 4 years ago.(keeping the grill Chrome though )His front bumper is awesome too, never seen another like it!
@Kiwi TJ how about showing off the front of your rig!?
Wow. How'd you get the JEEP stenciled in there?Front Bumper as requested ...It was polished steel...but I felt it was too much bling so painted the bumper black about 4 years ago.(keeping the grill Chrome though )
I don't know … It came with the Jeep when I bought it...not sure if the PO did it, or whether you can buy them like this.I've not seen another one, yet !! lolWow. How'd you get the jeep stenciled in there?
