Hello everyone. I’m new to Jeeps and new to the forum. I’m also not terribly mechanically inclined but am trying to learn. I got my first Jeep TJ a few weeks back. 2000 jeep TJ 2.5l 5 speed. 151k miles.
I tried to look through the forums for what’s going on but wasn’t sure I found quite the same issue. If it’s a duplicate forgive me.
Backstory: I drove the Jeep yesterday just fine around town. I had a headlight switch issue where When is pull the actuator towards me, the parking lights and headlights came on but not dash lights. I had to push the actuator back to just the right point where they both come on. My father in law picked me up a switch at the wrecking yard and I disconnected the battery and hooked it up. The headlights work as they should now. I never started the Jeep to test, just put the key to on switch.
Fast forward a few hours and I want to go to the store. Key in, crank it and it sputters for a second and dies. Didn’t do a normal startup. Keep trying and it continues to crank but no startup. The dash lights come on, gauges work, radio kicks on, overhead lights, I can kick on the headlights, etc. it continues to crank but never fully starts. You can hear it almost try with a slight sputter here and there.
I hear what I believe is the fuel pump at start still. I smell a bit of fuel up at the engine after a few start attempts. I checked standard 20 and 10 fuses and didn’t notice any issues. About a week ago my neighbor and I checked all the spark plugs and the cap and rotor. I ran seafoam through it this week as well. It seemed to stop starting after disconnecting the negative terminal and installing the switch for headlights. With all that in mind, does anyone have any suggestions based on my situation?
