Remember when
Remember when you had to double the clutch as there was no synchro between the gears
Still that way in heavy trucks. I usually start out in a different/new truck using the clutch to disengage the gears but slip into the next gear without the clutch until I get comfortable shifting without the clutch.
Reactions: Kiwi TJ
Remember getting S&H Green Stamps at the gas station, and "buying" stuff with them when you filled up the book?
Remember when you had to double the clutch as there was no synchro between the gears. (no quick changing back then)
Remember Cross ply tyres (tires) and how much they gripped in the wet...or not haha
...and how the bias ply tires developed flat spots when they sat too long, or if it was cold out?
used gravity,,,, this one is a half hour from home.
Hand pump the gas into the glass vial. Pay for the volume. Pull the lever to flow it into your tank. I buy gas there every time I pass it. Could care less about the price.View attachment 64319
Oh man !!! I looooove that...I can see why you gas it up whenever you pass through
