I have a 2006 Wrangler X. The blinkers and hazard lights stopped working all of a sudden. Everything else in the Jeep works. All of the parking lights come on, the cab and dash dimmer 'switch' works. I have already swapped out the flasher regulator with a Novita LM470. Fuse for the blinkers is intact. I'm not sure what else to check or what I can do to avoid throwing hundreds of dollars in parts at it. I've seen numerous other threads out there pertaining to this issue, but I don't believe I have seen a solution to it yet. Any suggestions? I'm not sure what to do next and I'd like to avoid taking it to someone for as long as possible. Thanks in advance.
