So my 97 2.5 has oil leaks. I am replacing the valve cover and oil pan gaskets but the rear main seal is also leaking., Seeing it is a 1 piece seal I do not have time to pull the trans til spring to replace that seal. Has anyone used oil leak seal additives with any luck? I just want to get through the winter. If so what brands seem to work the best? Thank you
