No problem! Sounds like you may have sort of figured it out. It clearly has something to do with your new headunit, and likely the way it was wired.
I'm glad you tried this our first, last thing I would want is for you to go wasting time trying a bunch of other stuff.
I think my first idea of a loose wire is the root cause, the symptoms started when I wired in the stereo because of wires moving in the dash. Today I’ve got the dash mostly apart, started it and then shook the fuse box and the dash popped to life.
Pretty sure it’s the keyed switch wire from the fuse 10.
