So it's a gorgeous day out today and I decide to take the TJ out. I go outside, start it up, and it runs fine for a minute.
After a minute it starts sputtering very aggressively, then dies. I start it up again and it starts, but it sounds like it's running on 3 cylinders. It's sputtering like crazy, and then 15 seconds later it dies. I continue to start it, and this continues to happen. It will run for 15 seconds max, but sputter out and die.
Eventually it just stopped starting altogether. It will turn over and crank, but it won't actually start.
No error codes or anything.
My immediate assumption is the fuel pump. Why you ask? Well when I cycle the ignition, I no longer hear the fuel pump priming at all. I checked the fuse for the fuel pump under the hood (as well as the relay) and it's good.
I'd love to test the fuel pressure at the rail, but they got rid of the Schrader valves on these things sometime in 2002 (screw you Chrysler!).
What do you guys think? Is my train of thought on track here?
UPDATE: I lied. I guess all that sound deadening material made it impossible to hear the fuel pump priming inside the vehicle any longer. I just had my neighbor come over though and he cycled the ignition while I sat under it. The fuel pump is indeed priming after all.
