Hang on, are you guys talking $1,600 for tires, wheels, and a lift, or just tires and wheels? I'm a little confused. $1,600 seems really, really low.
... rolling backwards is another. Trying to climb up walls in Moab with 4"+ of lift would not be fun. I saw a guy a few years ago on Poison Spider, with what looked to be a 5.5 RE long arm and 37's, get saved by his spare tire carrier. ....
There are qualities of that arm design that would encourage the Jeep to want to fall over backwards. It isn't necessarily the lift height that is the problem.
I won't disagree with the concept. But translate that into Jeep speak. How tall and what angles are we looking at? I have leaned mine similar to the blue Viking TJ. Once I get over my psychological fear, I eventually realize that the Jeep is fine.Agreed. But there is still something to be said for LCOG on steep climbs. At some point, it all comes down to what the math says. The closer to the ground your COG is, the harder it is to put the COG over an unsupported part of the Jeep (IE not within the rectangle defined by the tires). This means you can put the Jeep at a greater angle without rolling over.
Jeep builds really come down to what you're looking to do with the Jeep. If you're just trying to climb steep stuff, you're going to want to keep the COG as low as possible. If you're trying to have a nice Jeep to drive around with on the road and trail ride, you don't need to necessarily worry about COG as much.
I still believe you're making way too big of a deal over COG and your drawings are overly simplistic as they define the problem far too narrowly. As jivw said, there's a lot more than just COG at work when worrying about whether a TJ is going to fall over backwards on a steep climb or tip over when off-camber
On Hell's Revenge, I was trying to get up a climb after stopping on it. My front wheels lifted off the ground and I pivoted around 20 degrees to the left. Whether that is due to suspension geometry or COG, I don't know. But from my experience driving LCOG buggies in Moab, I think it is due to COG.
People are confusing center of gravity and center of mass.
The center of gravity shifts as the object moves. Specifically, the center of gravity is the point at which gravity acts upon an object.
The center of mass of an object never changes. It’ll remain constant regardless of outside forces (such as gravity).
“Low center of gravity” as it’s being used in this thread isn’t really a thing. “Low center of mass” makes more sense — somewhat — but it’s redundant. Center of mass is center of mass. There are no variables. You can build a TJ with a low COM, but it’s still called COM.
What you’re describing in your trip to Hell’s Revenge is center of gravity, yes. However, you’re combining the two terms (COG and COM).
Your TJ has a COM that remains constant. When your front two wheels left the ground, it was because the COG shifted. That is to say: gravity began to take over. The COM of your TJ remained constant.
I somewhat agree with @Jerry Bransford in that COG is overused, but that’s because it’s used interchangeably with COM — but they’re not the same thing. Building a TJ with a COM that suits you is possible, but the COG will always shift.
Sure, the COG can shift around, but it for the sake of discussion it doesn't really matter.
You don't seem to understand that this sentence completely contradicts everything you've written in this thread, and it's because you don't understand the difference between COM and COG.
They are not interchangeable. To claim otherwise is willful ignorance and could potentially be dangerous.
I'm not sure what the argument is either. However you want to describe it, the desire to not flip over is clearly understood.
I'm still confused as to what your argument is about COG (or COM) in a TJ? What are you trying to say?
On my 2005 TJ I have Toyo 285/75/17s on a Rough Country 2 1/2 lift. Previous owner put lift/wheels/tires on. Paid about $3300 with labor. According to Toyo's website the overall inflated diameter of the tires is 33.9". No body lift or motor lift. Works fine, no rubbing for what I have done here in FL.View attachment 73300
I don't really know how much simpler I can make it beyond "COG and COM are not the same thing and are not interchangeable".
I mean, if you want to keep using the term "center of gravity" incorrectly, go right ahead. I was simply trying to help you understand the difference between the two.
Oh well.
