opened the rear diff and a silver shower came out. time for new gears. something i needed to do anyway. 5 speed manual 97 sahara 4.0l with 35" tires. should i be going with 5:13 gears?
I loved my '97 TJ's combination of 4.0, 35" tires, and 4.88 gears on both the highway and offroad. 5.13 seems a bit low if it will see much highway time though it'd be great for a mostly offroad Jeep.opened the rear diff and a silver shower came out. time for new gears. something i needed to do anyway. 5 speed manual 97 sahara 4.0l with 35" tires. should i be going with 5:13 gears?
Thank you jerry. It’s gonna see more highway time than anythingI loved my '97 TJ's combination of 4.0, 35" tires, and 4.88 gears on both the highway and offroad. 5.13 seems a bit low if it will see much highway time though it'd be great for a mostly offroad Jeep.
Chris according to that chart it said 5:13. That’s what led me to pick those gears. But they are saying 4:88
Even if it’s mainly a highway Jeep. I wanna go off-roading some but nothing crazy. At least at first.I would lean towards 5.13 myself. That would be a slightly lower rpm than my current 33s/4.88/5 speed, which I like quite a bit.
Mine is a daily driver that does just fine on the highway.Even if it’s mainly a highway Jeep. I wanna go off-roading some but nothing crazy. At least at first.
is there data showing rpm and shifts with 42rle as this posts says i should be running 5.13 gears for 33" tires currently still have 4.10 gears
That is correct.
My old TJ was a 42RLE with 33s and I installed 4.88 gears. I always ended up regretting that, as 5.13 would have been the better choice.
The 4.88 gears were better than the factory 4.10, but with that horrible .69 overdrive ratio in the 42RLE, the 5.13 is a much better choice.
You'll sit around 2400 rpms at highway speeds, which is where you want to be. The 4.0 should not be below 2000 rpms at highway speed when cruising.
Second this! DO NOT re-gear the 42RLE with anything that will put you below 2000 rpm cruising. I'm on 35's with mine and just purchased 5.38s to be able to keep highway speed. Haven't installed them yet but based on everything I've researched here i'll finally be able to use my OD on the highway!![]()
It does go into OD early like 45mph and that's around 1500rpm...if I'm not going over 50 I usually turn OD off
With 35's, 5-speed, and 4.88 I'd only have to downshift to downshift to climb a grade or to pass traffic. I was usually towing my pop up tent trailer whenever I was on the highway. It towed so well I literally had to regularly check the mirror to make sure it was still there.Jerry, when you ran this combination, did you have to downshift much from 5th gear on the highway? Ever tow a small trailer with this combination?
