Worth it to get a spare 32RH?
Nathan Stanfield
Wichita, KS
I found a 32RH transmission from a 98 Jeep on Craigslist today and the guy wants $200 for it.
My 2002 TJ has 125k on it and probably needs the bands adjusted and sometimes has a tendency to kind of bang into reverse.
Would it be worth it to get the one for $200 to have as a spare or am I just being too paranoid that the one I have might not last much longer?
If nothing else it could be something to tinker with this summer.
How much to get yours rebuilt? IMO the issue with a CL sourced unit is you just don't know what you are getting. So you could spend 2 bills to get a tranny that needs rebuilding.
I would grab it in a second. It is a great way to learn about the transmission without having to tinker with the one in your Jeep. Couple of comments from your post.
1- Band adjustment is insanely simple to do. There is one external adjustment bolt and another internal, meaning you have to drop the pan and refill the fluid. It requires a wrench/socket to loosen the locking nut and a torque wrench. Search this forum for a really good write-up. There is no reason to not have these adjusted, in my opinion.
2- Many shifting issues are the result of an incorrectly adjusted TV cable. This cable connects the throttle position to the transmission's valve body. This allows the transmission to regulate pressure in the valve body based on how hard you press the gas. It also controls the kick-down of the transmission. If the cable is as tight as possible, the transmission will not shift until the RPMs are very high, but the shifts will be more abrupt. What typically happens is the cable stretches over time resulting in 'soft' shifts which wear the bands and clutch plates quicker. Neither extreme is good for the transmission. Luckily it is very simple to do and there are also a couple posts on this forum or youtube, for that matter.
If I had access to a $200 transmission, I would grab it, buy a rebuild kit and have some fun doing it myself. These are very simple 3-speeds and since there would be no rush, you could take your time and really learn a useful skill.
Tolerances are the only thing that you have to get within spec and they are accomplished with thrust washers. Most kits will come with a couple thicknesses but if you need to get a different size, you are stuck waiting on the mail. This is obviously an issue if the Jeep is your daily driver. Not so much if you are playing with a second tranny. Once the rebuilt one is installed and you drive it for a couple months, I bet you could sell the old one for the cost of the craigslist one and the rebuild kit.
No idea, but I was thinking of getting this one and rebuilding it myself. There isn’t any nearby shops that I would trust with it anyway.
I would never be willing to throw something from CL directly into my Jeep, especially a tranny.
Thanks for the info. If nothing else it’s something to entertain myself and learn from like you said.
I’ve done my front/rear gears, transfer case SYE, new lockup solenoid, and a manual t-150 for a CJ successfuly so I’m pretty sure I could handle this too. My TJ is just for fun, my daily driver is a new ram, so luckily I don’t have to be in a rush with anything.
In the meantime I will probably adjust the bands this weekend or next. It looks easy enough.
Reactions: tquig01
If you can handle the other work you did, you can handle the transmission rebuild. Things really can only go together one way, aside from the washer sequence. Certainly no harder than re-gearing by any stretch. I wish I could find a deal like that locally! Oh, and check your TV cable when you do you bands. It is an easily overlooked maintenance item.
Will do, thanks for the advice!
