@Wranglerfix could the problem with this be the skim of the donor computers?
No, the SKIM not being correctly paired to a swapped in PCM would result in starting and dying before you get it out of park and there would be a light on the dash showing that to be the issue. Unless you are misinterpreting it dying within 3 seconds or so as stalling under load. Are you?
I have a degree in physics and a minor in chemistry and I'm still amazed that they can design a fluid to act in certain ways like this.
The development of ATF+4 is pretty interesting if you can find the story about it. They were having a lot of transmission issues in front wheel drive mini-vans and needed a solution to solve a host of problems. ATF+4 is stupidly high quality and almost fully synthetic to get it done.
Using donor computer (99TJ 4.0 auto) it starts and stalls within a few seconds. Put original computer (99TJ 4.0 manual) it cranks and runs fine. Not worried right now about shifting.
Reactions: Wranglerfix
Is the dash light on when it does that key symbol with a circle and slash through it?
It sounds like the 99 auto has skim enabled. Do you known if the key was grey? I can program the 99 manual to auto if you send it into us.
That was my next question to you if you could do that. Awesome. I will send it. I have looked up the site and think I found the area for this. Can you post the link so I can pay you and get the shipping address or if you can message me directly. I can’t yet since I’m new here
You had commented on this before on another forum and a few years ago, I went and found a copy of that SAE paper (though my school contacts) you are referring to. Here is the link on the SAE website - https://www.sae.org/publications/technical-papers/content/982674/
It's a really freaking good read. The information is not difficult to digest at high level either. I have attached it here for anyone that is curious and I am going to tag @Mike_H given his interest in stuff like this.
Cliff notes for folks that want a summary without wanting to read the paper - https://bobistheoilguy.com/forums/threads/atf-4-rant-on-allpar.110206/
So, It was the computer after all...and maybe some me. Sent the computer to be flashed with the automatic transmission and it all works great now. I was seeing it as a stall with the 2 new computers I tried, but I guess both of them had the skim still on them whereas mine didn't. Thanks to @Wranglerfix for the extremely quick turnaround on the computer! Also making sure the trans fluid is full helps too. Didn't realize if it's low it does absolutely nothing.
