Harlyman
I did this swap about a year ago. Off the top of my head you need trans,tc will interchange from manual.
Shifter
Shifter cable
Flex plate/bolts
Block off plate from clutch cylinder.
Brake peddle assembly.
tv cable. You can get that new.
If the trans dosnt come with dip stick and tube. Hard to find
If you have a lift I would get sye/drive shaft.
Send ecm to Marks Wrangler to get switched to run auto/lock up converter to work.
All the wiring is there. The clutch switch I hooked up to momentary switch and use it for theft deterrent.
I went ahead and put a Derale trans cooler in.
The swap wasnt to bad. Had to use a big step drill bit to drill hole in floor board for shifter cable.
A good place to get used parts is Partsshowdown and oldbarnclassicllc.
Shifter
Shifter cable
Flex plate/bolts
