After I install the uppers I’m going to take some measurements and send pics of driveshaft angles. I wanna make sure all is well before I go drive it after the arm swap. Just not sure exactly what angles I’m looking for and what’s good and what isn’t.
I don’t have an SYE (yet) it’s next on my list now that I have the control arms. It has a transfer case drop on it to help with the angle I’m guessing. Once I add the SYE can I remove the transfer case lowering kit.
That piece looks to be bent in such a way that it's rotated around (hence the groove marks) from the position that holds it in place.
I'd either try to get that lip back in place so it holds itself while you loosen the bolt, or I'd have someone grab it with some vice grips while you try and get the bolt loose.
