Tailgate sags: Which hinges to get?
Chigger
New England
My tailgate ('04) is sagging. Just wanted to see what people use for aftermarket hinges. I am looking at a set of Kentrol or Rugged Ridge. I also see Crown and Taylor make a set. TIA!
I've got the rugged ridge kit... Very sturdy and smooth pivots! I'm actually taking the kit off this week to install a bumper/swingout combo.
Sent from my Pixel 3 using Tapatalk
How big is your spare? I personally like the exogate/MoRyde system if you’re running something bigger and don’t want a swing out. It’s likely overkill if you don’t have 33”+ tires though.
I’d remove the spare tire from the tailgate at least from the time being and throw it in the trunk! I’d suggest a swingout tire carrier personally. Not only will it fix your issue but it’s a nice excuse to get a new bumper in the rear as well. They can be had for almost the same price as aftermarket hinges or braces I believe.
I personally suggest the Exogate / MORryde tailgate / hinges. Your tailgate will never sag again. Talk about some seriously beefy hinges!
For a 31, don't overthink it. A new stock set or the Exogate hinges is all you should need. Make sure the door is adjusted correctly and the tire is tight against the snubbers.
Reactions: billiebob
I love my Exogate.
The only issue is that I cannot currently use my Kargo Master Congo cage roof rack with it now.
(Hoping to figure out an easy way to mod the rack to allow the use of both).
I bought a set of Kentrol hood hinges a while back. They started chipping pretty early. Unless they've changed their manufacturing practices recently, I'd steer clear of them.
Hi,
I'm sorry for being so clueless but I'm having this issue. Which bolts need to be loosening and re-tightened?
Have you removed the spare and checked for play in the hinges?
As far as adjusting, most start with the four that go into the tailgate.
You may also need to adjust the latch pin.
Reactions: kmbarreiros
I'm running the MORryde HD hinges with my 33" spare.
No additional tailgate reinforcement.
