If you can afford it, buy this impact:
https://www.homedepot.com/p/Milwauk...ith-Friction-Ring-Tool-Only-2767-20/302654201
Brushless motor so it lasts forever. 1,400 ft lbs of torque. I have never found a nut this thing could not bust. Took off a 36 mm F150 axle nut with ease that I couldn’t even budge with a 4 foot cheater bar. Completely destroyed a ball joint press. Definitely one of my most used tools.
I have had no issues with the Husky 1/2” impact socket set even with the impact wrench I use.
As for torque wrenches I recommend CDI Torque products. It’s a MATCO brand, and they’re a step down from the Snap-On line. They have a bunch of different sizes.
Combination jack/jack stands are a great time saver. Tractor Supply Co has the Powemaster ones. They go plenty high for most purposes.
Torque limiting impact extensions are great for blasting on lug nuts. I’m probably going to pick up a basic Husky set. Blast the lug nuts on with an 80 ft-lbs stick and finish them with a torque wrench set to 100.
Brake cleaner for light grease/oil, Goof Off for heavier stuff. WD-40 for cleaning and coating painted surfaces.
Air compressor, preferably with a large tank. Flexzilla hose bends easily without ever kinking.
20 lb fire extinguisher for the garage, 8 lb for inside the heep. Carbon monoxide alarm in the garage. Large supply of gloves, ear plugs, etc. Quality safety glasses.
3 amp battery charger to power the car stereo while working.
