Need help with wiring electric radiator fan
That looks like some well designed stuff. I hope you weren't planning on a rear Anti-Rock mounted in front like I do them.
I’ve been rounds and rounds about the rear AR and decided against it. I believe it was you that said they can limit up travel if I recall. It’s been a while since researching it.
Yeah Chris did a great job. Pretty limited on places it would fit. We discussed options for about 30min and I just turned him loose. There is not a single hole/bolt coming into to cabin! Everything was kept on the exterior. The fan can be separated without removing the rad. This is hours of Chris and I talking and getting to know each other. He’s well aware I’m willing to spend a few extra dollars for a quality job.
I've never said they limit travel because they don't. What I have said is you only install one when you break the OEM version a few times or you have extracted all the performance you can get out of your suspension and are looking for that last couple percent of improvement.
Do you have to cut/modify the wheel well? There was something that made me decide against it. Unfortunately I don’t remember and now I will have to go back and figure out why that was.
Second one is how you would do yours.
Reactions: Powdermonkey
Well the first part is done. Haven’t decided yet if an air intake of some kind should be added. To help with the added distance I will be using the Shelby GT500 pump. The system does have an expansion tank that will should ensure all air is removed.
View attachment 90318View attachment 90319View attachment 90320
Revisiting this. Powdermonkey, is this a fabricated piece with MP's heat exchanger? Details & part #'s please as I'm about to embark a MP supercharger install, too.
