Fun at the Beach
Robin Down
Took my '99 TJ out with my club on it's first run, fitting it was Oceano Dunes SVRA which I have loved since my first time there back in 2002. My Jeep has been getting some upgrades since I bought it completely stock. Currently it has a 4" Trailmaster lift (cheap short arm) and 33" tires that I swapped from my '95 Cherokee. Aside from some electrical doodads (CB & Rugged Radio, new Pioneer deck, rock LED lights, backup LED lights, and pillar-mounted LED lights) I have also added front & rear bumpers, 9500# winch with synthetic line, swing-out tire carrier with mount for Hi-Lift and shovel, and rock sliders. I am getting ready to swap the front Dana 30 with a HP-Dana 30(cherokee axle) with ARB and 4.88 gears, and swap the rear Dana 35 with a Dana 44/Detroit locker and 4.88. Also the rear has a Teraflex Disc brake kit on it and chromo axles. I also got a used Nth Degree bellypan which I intend to swap with the stock pan, and eventually upgrade to a long-arm suspension.
Overall this was just a shakeout trip for the current setup, and it did not disapoint! I had a blast cruising around in 2wd, 4wdHi, and once in 4wdLow. The new lift was a little stiff but after some good bouncing around and one or two (small) jumps it has softened up a little bit. :)
Where is this at (i.e. what city / state)? Awesome photos, that looks like such a blast.
I take it that it did pretty well in the loose sand?
Reactions: Robin Down
Looks like a blast. I have wanted to do a beach trip for a long time. My buddy used to ride dirt bikes on Pismo all the time.
@Chris, it is located basically between Monterey and LA.
I didn't even know that area was there - I drive by Pismo all the time when I go up to San Simeon and beyond!
Going to have to check it out next time I get up that way.
Do the trail flags have to be a certain height above the vehicle? or what is the standard?
I see some that are like 5ft, then I see some that are 8ft...i'de like to get a flag kit.
This was at Oceano Dunes SVRA in California, near Pismo Beach.
My jeep did great out there - no lockers, 3.73 gears were a little weak for 33" tires but overall I was very pleased. :)
They sell all kinds of flags - and depending on your mounting location it could be higher/lower.
I've always used an approx 7 foot flag attached to my bumper, but this new one is 5 foot attached to the top of my tire carrier.
Reactions: EJD
You have the Quadratec one?
Quadratec one of "what"? the flag or the bumper? Answer is neither.
The flag is from Amazon (link above) and the bumper is a Smittybilt with tire carrier.
The old flag I have used before was 7 or 8 feet long, and has a picure of a mug of beer on it! :emoji_beer:
Haha, I meant the actual flag mount. I was looking into that one and was hoping I could get someone to vouch for it. I'm sure its fine.
Oh gotcha! well, so I have the Teraflex CB/Flag mount on both corners. These mount behind the taillight and stick out to the left or right on either side. I have my CB antenna on the left and my dual-band Ham antenna on the right.
For the flag mount - i used a metal bracket that I had in my garage. I believe it was part of a muffler hanger kit? It is bent into an "L" shape and has one big 3/4 inch hole at the top and several small 1/4" holes on the bottom. I used self-tapping screws to attach this bracket to the top post of the tire carrier, and the Flag mast has a quick-release mounted to that bracket.
Reactions: EJD and Chris
