Harmonic vibrations in Jeeps: A new theory (please read!)
Big update today.
My post re-gear vibrations are resolved. Yes! Finally!
Been working with a great local drivetrain specialty shop that's finally helped figure out the problem. There was no one root cause.
The on-vehicle balancing I posted a couple pages back helped. But not completely. The shop then replaced 2 items (front driver inner axle shaft and rear driveshaft yoke on the axle side), and adjusted pinion angles, followed by one more round of in-vehicle balancing. The vibes are completely gone as of this point.
I'm waiting for a detailed write-up from them and I'll post it here as soon as I get it.
Big thanks to everyone when has helped me and encouraged me and taught me. I owe you all a beer.
@JDRAM11 is going to try the same techniques at the same shop in a short while. We'll see if he has success as well.
Yes! Finally!
Yes, looking forward to the write-up.
Congrats on resolving the vibes. Sure hope more of us can benefit from the fix.
Believe me when I say that NO ONE here could have had the harmonic vibration as bad as @psrivats. I drove his after the gear install and it was nuts. At 40 mph that thing was vibrating like crazy.
IMHO after seeing and hearing what he has been through, the only place that can successfully fix this sort of vibration is a speciality drivetrain shop (like the place that fixed his) that treats the vehicle as a whole as oppose to just tearing it apart like Dave and Chris did at Jeep West, trying to replace every single thing and find the one thing that was bad.
It wasn't a case of one thing being bad, it was a case of a number of things needing replacing, and the vehicle needing to be balanced as a whole as oppose to just saying, "Well, let's try and balance the driveshaft and see if that does it.".
These guys clearly know their stuff, that's for sure. I look forward to your update as well @JDRAM11.
It seems like TJ owners may finally have a solution for an issue that has long plagued the TJ platform, with seemingly no solution (until now).
I think you still need to check all the usual suspects.
I would strongly recommend anyone thinking of re-gearing to check everything very thoroughly BEFORE changing the gears. The gears themselves don't cause the issue (unless there is a setup problem), but the highly increased driveshaft speed will bring even small imbalances to the forefront. The vibration dampening methods (thicker skid, dynamat/noico) are need to address the resonance issues that arise on the side.
Reactions: AndyG and Chris
No different than any of our discussions. Each thing has to be checked and eliminated.
Mine is going under the knife to get some suspension work done, once it gets out, I Will take it to 6 states to get it evaluated as well. My vibrations lessened a lot, but I still have a very small one, will keep you guys posted.
Reactions: psrivats
It seems to point to bending ears when installing the u-joints on that inner shaft and rear pinion unless the factory tolerances are just not so good. Did the same shop/person do both of those? It is great that it's resolved.
Big update today.
Congrats! Now go enjoy that thing
Big update today.
Great to hear man! Patience has paid off in the end (y)
And he was soooooo close to selling it too. I remember getting many a text message from him saying he was done.
Looks like they solved it just in the knick of time!
In all honesty, I don't blame him either. That vibration was absolutely unlivable.
Reactions: tomtaylz
That's honestly not surprising, most would've gotten rid of it a long time ago!
Dude. Man I’m so glad for you , and hats off to the shop that solved it....vibes , squeaks and pops can be elusive Good on you for persistence. Almost all problems yield to persistence.
It’s summer . Smile , congratulate yourself , drop that top , drive and grin.
I agree something is to be said for all the brotherhood on here ...when a TJ doesn’t give you the love back, the forum can.
Really some cool, knowledgeable people on here, and that has value.
