I was rotating my tires and looking for an occasional clunk I get at slow speed turns. I saw the angle of my Drag Link rod end connected to my Pitman arm. Is this angle normal?
If your wheels are pointed straight that balljoint angle seems greater than my brand new DL that I just installed. Not much but noticeable. I’m only running a 2.5” lift though. My old DL ball joint was shot. I could easily pivot with light finger pressure. The attachment at the tie rod end was not as bad but still a bit worn. Now there is very little rotation between the Tie rod and DL which the rotation is know to create a dead spot and steering wandering.
Still trying to chase down this occasional knock at slow speed turns. Track bar looks good during dry steering test and I jacked up drivers side front tire for a shake test. I just ordered items for ZJ steering upgrade I've been meaning to do, hopefully its something along those lines...
ZJ upgrade is a good idea, I advise the DL too although not a upgrade per se. This will replace 4 joints leaving only the TB and possibly the damper mounts. If the noise remains it could be the ball joints. That is the only thing I have left to replace and my front will be completely refreshed.
