I'm setting up a TJ for flat towing. I would seem to me that the steering damper might resist or inhibit the front tires from steering as quickly as they should when the jeep is being towed around a corner. Does this make sense?
It's a non-issue. If it was the factory would include information on it in the owner's manual where it covers how to set it up correctly for flat towing.
All you have to do is unlock the ignition switch, shift the transfer case to Neutral, and shift the transmission into Park or into a forward gear. Do not flat tow with the transmission in Neutral which can damage it.
If that OME damper is gas charged I'd seriously consider swapping it for a hydraulic like Rancho's RS5000. Gas charged steering dampers keep trying to expand which tends to push/bias the steering toward the left.
Jerry, with a manual trans. should one put the trans. into a forward gear as well as the transfer case in neutral? I can understand how putting an auto. trans. into neutral can cause damage but am at a loss as to how a manual trans. can be damaged if the transfer case is in neutral as well as the shift lever.
Having a gas charged S/D is not a bad thing if it pushes slightly to the left. Considering most roads are engineered with a crown in the center. And it's not like it's going to yank the steering wheel out of your hands. C'mon
