So, I went to the Yamaha dealer to get some stuff for my scooter and a couple of the salesman were looking at my TJ. When I was going to the door they started talking to me about it. In the conversation I told them about how I traded my Liberty in on it and how the Liberty had all kinds of problems. Then I said "knock on wood" the TJ hasn't had one yet! Well, I must non have said the "knock on wood" loud enough and there wasn't really any wood to knock on and of course, this morning on my way home from work the check engine light came on for the first time since I have owned it.
I hooked my code reader to it and it showed only 1 code. P0300 Multiple Cylinder Misfire. My code reader has a "code connect" it will tell you the most common fixes, starting with the "top reported fix" first. The "top" fix for this code was replace spark plugs. I actually put all new plugs and wires in it back on January 25th. (this is the nice thing about having a "build thread", one can go back and see when she did stuff, LOL) I'm thinking the plugs are probably not the problem.
My code reader has SEVERAL other reported fixes. I'm going to post pics of the screen, yah because I'm lazy. LOL
There are about 16 or so other fixes going all the way up to rebuilding the motor. Hoping it won't need that. Yikes.
I have decided I'm going to start off with cleaning the mass air flow thingy. Here is a pic of it,
I know it's not the "clean engine carbon" that they are probably talking about, but I figure it is a start.
I have a question on this next pic. What is the black box at the bottom of the pic? Would that be a possible problem causing my code? Also, what is the thing the white connector on the right of the pic and what is the thing to the left of the black box?
I can tell you a couple things I have noticed since owning the Jeep as far as how it runs. It seems to run pretty good, once in a while I will get a weird rev up when I first start it, but nothing to extreme. Once when I started it to leave a restaurant it kind acted like it was "loading up". I gave it some gas when I went to go out onto the street and it was fine. Then there was the time I went on my 3 hour drive and it acted like it was missing at stops, but no code came up and in my build thread we determined that a heat shield would help fix that. I did put a heat shield on. When the check engine light came on this morning, I was making a right hand turn from one street to another and I took it a little faster then I normally do. Right after I made the turn, the engine light came on. The Jeep still ran fine and I didn't notice any missing or anything. All gauges were at normal readings.
Any other suggestions? I would like to start by doing the cheapest fixes first and see how it goes. Right now I have cleared the code and I drove to the hardware store and back and the light has not come back on. KNOCK ON WOOD Yes, I did actually knock on the wood this time. LOL
Thanks for any help you all can give.
