I was looking at Savvy Under Armor today and didn't see anything specifically listed for the TJ SE. Am I correct in assuming that there are no TJ SE specific under armor bits from Savvy, and the 4.0 bits are not appropriate?
Well, haven't heard back from Savvy yet.
They're either still laughing so hard they can't talk yet, or furiously engineering a conversion to meet my needs.
They are all out practicing for KoH... I talked to them last week about it...There may be some sort of event going on (Blaine or Jerry might know) down there way that has them out of the office. We'll see...
Nope, same transfer case as all the rest (Rubi's excepted)I don't see why the 4.0 transfer case skid wouldn't bolt on. Is the transfer case on the 4 bangers different?
That would explain it... Thought it might be something along those lines. Like I said, I'm not all that worried about them getting back to me immediately.They are all out practicing for KoH... I talked to them last week about it...
I did just order a skid from them for my 00 sport with an auto trans (which I didn't see listed -just manual) though.
But, yeah, I would expect a little delay on the reply because of them being out in Johnson valley
I haven't seen an UA offering for the 2.5l, just the 4.0. Just within the last few months did is they develop the kit for 97-02 auto. They hadn't had much demand so they didn't bother (that's what I gathered from the thread) until a few people asked about it.
It's possible that with a few inquiries, they could develop one for the 2.5.
Blaine may have an inside scoop, above is just what I read.
That I don't know @Chris. Don't you have Savvy UA on your rig? Parking the two side by side and throwing a tape and taking some pictures would tell the tale.Then I don't get it... If the SE uses the same transfer case as the other TJs, why wouldn't a 4.0 skid plate work on the SE?
LOL...well alrighty then! For some reason I thought that you did.I don't have it... yet!
If all of the mounting points on the 4.0's are close to what they are on the 2.5's, then it should theoretically work, right? At least close enough.
Mounting points, on the 2.5, are just a little different sometimes than all the rest of the TJ clan it seems. Starts with the motor mounts and travels through the whole drive train. Lots of stuff is the exact same, and then the engineers throw a wrench in to keep you honest.Yep, that's my thought. I don't see any reason it wouldn't work, unless I'm missing something.
If I can stuff a 400 small block into a '72 Vega, this shouldn't be too much of a problem, right?Go figure.
Yeah, if things were just a little bit off, I suspect you could make it work with some creativity.
HA, I wouldn't think so!If I can stuff a 400 small block into a '72 Vega, this shouldn't be too much of a problem, right?
