I don't listen to the radio anymore so I removed the antenna the other day. I didn't find any other how to online so I figured I'd do a quick tutorial.
Step 1:
Unscrew the antenna from the base.
Step 2:
With a flat head screw driver, gently work your way around the plastic cap and pop it off.
Step 3:
Remove the 3 screws that hold the base onto the body of the Jeep.
Step 4:
Inside the Jeep disconnect the antenna wires from the radio and unclip it from the retainers behind the glove box.
Step 5:
Push the wire and grommet that is inside the Jeep out. Now the entire wire should pull out with the base.
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
