Awesome, I enjoy a good write up, pompous assery a lot less, some of us old timers weren’t as fortunate as you to have someone else design a suspension that would actually make a body lift even remotely considered function. I guess the rest of us that don’t have the Savvy MA and a TT will just have to rough it with our sub par form only mounted skids while you ride off into the sunset with your pants pulled up over your butt crack and your nose in the air. I’m a fan of function too, but I’m also practical and for what I do, mine functions fine, just like it has for the last 19+ years.
The body lift debates are about as old as time and the value of raised skids to compliment a spring lift has been known far longer than any midarm kit has been around. Really the bottom line is almost any center skid is better than factory. I think we can all agree that going as high as you are willing to go is always a good move. On the flip side, if the underside isn't getting caught on things to the point where it is considered a problem, then there isn't much point to changing things.
