I think...the Fox steering stabilizer can be adjusted via the valve. I haven’t found a need to adjust the Fox on my TJ, as a matter of fact it improved the highway speed “feel” of the steering.
All the major hardware is bundled in a kit? From where did you buy this rear view mirror upgrade?some of the stuff I've done...
Compass/Temp/Map Light mirror. The LJ has all t he wiring in place to utilize this. I just crimped on a simple dupont connector with the same pin pitch. Works great. The mirror came with a temp sensor that fits the socked built in to the LJ
Looking good! What...? No, not you...your Jeep.
If you don’t mind, please. No rush. I noticed the exterior harness awhile back and consider that Fraud/Waste/Abuse to have dead weight hitching a ride so, let’s see if we can put this thing to work. Plus it would be nice to see how much I’m freezing in the morning while out camping w/o a cell signal!The mirror was a used unit off e-bay. I can get you the exact number. It had a wiring harness and sensor attached but the plug was different. The built-in Rubicon harness had everything already wired up so I didn't have to mess with that. Just needed to plug in the mirror and the temp sensor. I cut the wires for the mirror and crimped on the Dupont connector. If you can skip the map light, you can find the mirrors all over the place for cheap. I was stuck on that damn map light so I had to drop $150 on the mirror.![]()
Awesome, thank you!Here's a graphic showing most of the Gentex line of mirrors. Mine is the 50-GNK30 or 50-GNK31. Not sure what the difference is between the two harnesses (Mito vs. Gentex)
If anyone is wondering about the Hooke Road bumpers, here's a little overview.
They go by a few different brand names (EAG, Vijay, Hunter, Ubox).
Front Bumper:
https://www.amazon.com/dp/B0753DCZBZ/?tag=wranglerorg-20
Rear Bumper:
https://www.amazon.com/dp/B07HJ3LCSJ/?tag=wranglerorg-20
I had been looking for a single-action tire carrier and they are muy expensivo. I was able to get the front and rear for around $700.
They seem pretty well built to me. Installation wasn't a big deal in spite of the crappy instructions. No surprise there. It's pretty obvious where the parts go, though it is a bit fiddly - lots of nuts and bolts.
The only real challenge was the rear bottom bolts that go up into the frame. The holes are just a bit short. If I would have test fit before putting in on, I probably could have made the hole bigger. Will need to use a dremel to do that now that it's installed.
Great thing about the LJ is that there is a lot of space between the bumper bracket and the fuel tank. No need to drop the tank to get to the bolts. On the TJ, you'll need to drop the tank to get to the additional screws inboard on the bumper.
Love the single-action tire carrier. Only gripe is the bumper that rides on the door. If you don't get it lined up perfectly, it will squeak and rattle on every little bump. Fortunately, adjustment is easy.
Also, for later model TJs, you will need to put some spacers on the plate that mounts to the tailgate. Otherwise you'll be closing up the vent in the gate. I've heard stories of people blowing out windows if that vent is blocked. I printed out a 1" spacer in carbon fiber and that did the trick. After doing that, however, you will need to shorten the bolts on the clevis that attaches the tire carrier to the gate.
Tires are 33" and I was able to mount it pretty low which helped a lot for visibility. Currently working on a bracket for the third tail light.
View attachment 121327View attachment 121328View attachment 121329
I’m digging the tire carrier attached to the rear gate, may modify mine with this setup. Great idea.
The exact reason I was thinking I need to mod mine!Google “single action tire carrier”. This was important for me as sometimes my wife drives the jeep and anything I can do to make her life easier means I can keep getting Jeep parts.![]()
