Probably bringing back an old one but curious what the thoughts are on the plastic rear inner fender. Debating removing and coating the body or doing the weld in style like Go Rhino used to make.
I removed mine. It was a lot nosier without them, but I made up for it with the Noico sound dampening material.
If I had carpet I would probably put some Noico down but I dont think it would look right without the carpet.
@jjvw Is it even possible to keep the rear inner fenders with outboarded shocks?
Mine are out(have been for a year) no ill effects regarding the EVAP canister so far. 06 LJAgree with @jjvw. It is very difficult if not impossble to keep them after a rear shock outboard. I like the cleaner look with them and I am not sure what will happen in 05-06 Jeeps if you remove them given the location of the EVAP system. I will ask Dave when I talk to him next time ..
I’m considering this as it’s always a pita to get the mud that inevitably finds it’s way in there. I have a 04, do you Colorado guys get a lot of mud? Here in MI it’s an unfortunate way of life even in areas that are mostly sand.
