First of all I'm new to the site. Thanks for the help ahead of time.
I noticed today some gear oil leaking around my rear passenger axle. So I thought i would go ahead and replace the rear axle outter seal and bearing. I couldn't get the axles pushed in far enough to get the C clip out. I thought it may have had something to do with the auburn locker on it. I finally had to beat it in pretty hard to get the axle in far enough to remove the C clip and then beat it back out to remove the axle. On every i got it out i think i know the problem i was having with not being able to get it out. Apparently the bearing went out and rubbed a big grove in it. Now I've got to replace the axle. It has 30 spline alloy USA axles and a auburn locker in it.
Am I correct thinking that that big grove shouldn't be there?
