Chasing leaks in NP231 transfer case
98TxTJ
Near Denton, TX
I hate leaks. The transfer case is driving me nuts. First I had to replace the rear output yoke and seal. Then the speedo gear o-ring. Today the front output yoke and seal. After a test drive, it is clear that the seal around the shift-linkage is also leaking.
I found a thread on here that assures it can be replaced without opening the case. Per RockAuto, this is National part number is the right seal: https://www.amazon.com/dp/B009B45UVU/?tag=wranglerorg-20
Anyone know differently?
Also, after spending all that time under there, I saw how bent and twisted was the shift linkage — probably done when the PO had the 6" Rough Country lift installed. (Since replaced with a 3.5" Rock Krawler.)
I've got a Savvy cable linkage on the way.
