Hey Guys,
As you can see, i got int a bit of a fender bender in the good ol girl and was looking for suggestions for things i havent thought of to start pulling her apart and rebuilding as needed.
As you can see, ill definitely need to replace the front grill, passenger quarter panel, Radiator, Hoses and Belt, Fan, and possibly some front mounted components (Water Pump, AC compressor, etc). I also noticed after the accident i was leaking transmission fluid, so probably the transmission cooler lines as well. (Yes i have the three speed Auto)
I also noticed my gas peddle seems to be bent, not sure if that was from me slamming the brakes in the accident or if something else happened.
Any suggestions on where to start besides the obvious of taking the damaged panels/components off, or any other suggestions to check? Would it be more beneficial and cost effective to replace with OEM parts or aftermarket?
Thanks in Advance!
Thanks in Advance!
