Well the only my doors fit is by removing those bars, otherwise the windshield frame is leans too much toward the door, which leaves no space between the door and the windshield frame.Those are adjustable. On the opposite end, you'll see one single bolt. To loosen it you'll need a security-type torx bit. T40 I believe.
Just a word for caution. When you do adjust it forward, it will affect your seals quite a bit. A little movement goes a long way. Me personally, I would try anything except for that.
