I SUCK at electrical, won't even try to lie. SITREP: New MCE fenders, 3/4" 3 wire LED lights (white- ground, red- 100%, black- 50%), OEM front turn/parking wires (black- ground, blk/yellow tracer- 100%, green- 50%) So far, so good? Hooked wires up respectively (side markers, still incandescent barely come on) and both turn signal indicators are illuminated on the dash, flashers work normal (including side markers), turn signals (including side markers) flash like a strobe light. Suffice to say, things are not normal. I hear an electronic flash relay will stop the turn signal strobe? I will wire in two LED side marker lights (2 wire, 3 wire?)- will that help with the existing issues? Do I have to physically ground anything or just use the harness ground? See, I TOLD you I suck at electrical.
