This has probably gone on for about a year and a half, but now it's bugging me. This scratching noise sounds bad, but truthfully the vehicle works fine. Transmission doesn't slip, but a little into 2nd gear when it's not warmed up. The pulleys are in order, none of them corroded or loose and the belt is still working fine with no tears. Changed out trans fluid with MTL two weeks ago but this problem has been around for a while. Any ideas? I should mention that when I changed the fluid I found some shavings in the drain plug (photo attached)
Trans: NSG370 (6speed)
109,700mi
109,700mi
