LJ rear cargo storage
Crozz13
Greenville, SC
I have an '06 TJ Unlimited (LJ). I'm looking for a rear storage cover that allows the rear seat to remain in place and is lockable. BestTop makes the InstaTrunk, but it isn't specifically made for the LJ. When installed in the LJ it leaves a gap between the seat and the secure part of the trunk. Has anyone found a cover for the rear of the LJ similar to the BestTop InstaTrunk?
I searched all commercially available storage options when I purchased my LJ but never found anything that fits your description. I might have missed it however.
I suspect you will have to fabricate your own.
This is what I did, but I run a hardtop:
https://wranglertjforum.com/threads/diy-interior-cargo-rack-for-lj.10707/
Reactions: skrelnik
I don't use my soft top anymore, but when I run my hardtop with the roll-up soft sides I use this trunk box from Gr8Tops for secure storage, it's designed specifically to fit in the LJ and makes optimal use of the cargo space in the LJ.
I've had it a long time, I used it with my soft top before I switched to the Safari Cab hardtop...
The box will fit under a tonneau cover.
Not to hijack, but may I ask where you got that rear window? I've never seen one like that and the typical zip open/close rear window on the soft tops is a real pain in the butt during hunting season if you're moving bows, rifles or backpacks in/out. Something like this would be great.
He made it :) Search for his other stuff on here. He is the designer of a lot of Jeep mods.
I run a duster on mine when I don’t have a top on. I also notched the plastic so I could run it with the back seat up and functional. Like this, not my pic.
The awkwardness of zipping/unzipping the soft top rear window always frustrated me so when I was designing my Safari Cab hardtop (which has a full rear barn door), I designed the "soft barn door". This of it as a soft upper for the tailgate the same way half doors have soft uppers. I built the one prototype pictured and ran with it for two summers. It worked great and relieved my frustration with the factory soft top rear window. Haven't done anything with it since I finished and installed the hardtop; with the Safari Cab's swappable hard sides/soft sides I have no desire to use my soft top anymore.
Impressive; my hat's off to you! Wish the soft top manufacturers sold something like that.
Reactions: skrelnik
Reactions: DrDmoney
The smallest Rigid job box from Home Depot fits behind the rear seat in an LJ.
its on the heavy side (70lbs empty) but I feel absolutely safe storing things in it.
also a plus- it's nearly impossible to remove without opening the tailgate even if not bolted down.
