Did you remove the carrier and ran it to see if that got rid of the vibes?So basically, the gear setup is fubared. Not sure how that causes the vibes, so I'll have to leave that to someone that knows way more than me about gears.
If only I had time to pull the carrier yesterday and spin the input shaft, like Indy suggested, I'd know for sure. I don't really know what I'm looking at, but I didn't notice any wear of the gears, nor any metal in the gear oil. They have 40K on them. BTW, I do have a howl noise at 55mph under load. It changes pitch at coast.So, the depth is far too deep; backlash too wide. It could be that the original installer ran the bl wide in an attempt to "cover up" the deep pinion depth. Opening up the bl can make the pinion depth appear less so, to a point.
Is this the cause of your vibration; I honestly cannot say. Been a long time but I do not recall dealing with vibration solely due to rear end set up. Most poor set ups result in noise and/or premature wear.
The noise is most certainly from the improper set up. I wouldn't run it without the carrier and no oil for long or you'll have another issue; fried pinion bearings.If only I had time to pull the carrier yesterday and spin the input shaft, like Indy suggested, I'd know for sure. I don't really know what I'm looking at, but I didn't notice any wear of the gears, nor any metal in the gear oil. They have 40K on them. BTW, I do have a howl noise at 55mph under load. It changes pitch at coast.
Irregardless, the setup isn't right and needs to be replaced.
I did take video of the ds spinning to 75mph and it looked true.
I hate it when people say it to me, so I’ll just say, “I’m glad you found it.” This will actually make me sleep better.So basically, the gear setup is fubared. Not sure how that causes the vibes, so I'll have to leave that to someone that knows way more than me about gears.
If you regear it, you might as well get a locker. I know, but still
Why the dislike of thick cut?Yes enabler, lol! While a locker would be nice, it'll add another$600+ to the cost, which I can't really afford as it is. I like the LSD in the rear. It's simple, and predictable. My wife occasionally drives the Jeep, so I need it to be predictable. A selectable locker would be nice, but it just adds to the complexity of the job. Heck, I'd keep the Traclok in there now if I didn't have to run a thick cut ring gear.
My thoughts on break in are follow what the manu says. Personally, I just drive it as usual. When I did Tom's Rubicon we used the REM gears, and there was break in info with them. So, whatever that means.
WCD used to be the parts dept for Ring and Pinion Service, where I worked. I really couldn't comment as I have been away from them for many years.
I'd be willing to do it for you but the diff would have to be out. Killed my back rolling around my garage floor for 8 hrs doing Tom's Rubi. Too old for that now![]()
