Can a TrueTrac LSD be swapped in the Dana 35 replacing the open diff & carrier without having to re-setup the gears? If so, how would I go about it?
Those were my thoughts too. I don't think it would be needed to install new seals or bearings for the axles. But a press would be needed to put the bearings on the new carrier, plus a puller because it probably wouldn't be to spec the first time.I'm also interested as I want to pull the spool the PO installed & replace with a locker. I figured it would just be a matter of using a micrometer to measure curren ring to bearing races and shim new install to the same
I was very lucky in finding a bearing puller to borrow from people I know a few times. Have you ever seen one for rent/borrow from an auto parts store? I have not after looking at several of my local stores.For sure. For a simple carrier swap dropping the entire housing is too much work. I have the Yukon bearing puller, generic calipers and dial indicator. The big issue is, the Yukon puller is expensive for one time use. There are others but I have not used them.
I have looked at the local auto parts but none had the correct puller. My guess is that it is a specialized puller so not much use for the garage mechanic.I was very lucky in finding a bearing puller to borrow from people I know a few times. Have you ever seen one for rent/borrow from an auto parts store? I have not after looking at several of my local stores.
I bought a generic clamshell puller. I can’t recall where I got it, maybe ebay but it was roughly $150-160 and shipped directly from India.For sure. For a simple carrier swap dropping the entire housing is too much work. I have the Yukon bearing puller, generic calipers and dial indicator. The big issue is, the Yukon puller is expensive for one time use. There are others but I have not used them.
As do I, have you ever done that to remove a carrier bearing?For those I always used a cut off wheel on my die grinder then a chisel and hammer to break and remove them.
Well dang, why have I been under the delusion I needed a carrier bearing remover all these years then?That's how I removed my carrier bearings.
