View attachment 1454 View attachment 1455 View attachment 1456 I just finished installing my Savvy LED taillights, my other ones the PO had on we're cheap intermittent LED's messed up , so I wanted factory style lights & opted for these they are slim machined from billet aluminum anodized black. I also ordered the license plate LED bolts but didn't install them yet. Taillights are really bright especially the backups.
Go ahead and upgrade @Chris and I'll buy those rugged ridge from you so I can see when I back up![]()
Barely kinda sorta. It has a hand-me-down nearly flat skidplate under it but that's about it. I got the skidplate free because it was bent, which took an entire morning to get it straightened out. It took using the entire weight of the Jeep's rear pushing on about 1 square inch (via a socket) of the skidplate before the bend finally gave up and straightened out enough to mount it.Jerry I can't tell...is your transfer case tucked?
And thank you Chris, Walker Evans does make good looking wheels doesn't he!
Sweet, and it looks like you're using Lightnin' Boltz LED bolts to illuminate the license plate. I love those things, they're the perfect answer for when you remove the old OE tail lights that also removes the license plate light.
Yep that's them. Those have been on both of my TJs, they work well.Is this what you're referring to?
http://www.amazon.com/dp/B000E243BG/?tag=wranglerorg-20
I absolutely love the Savvy LED taillights. Spare or not I think they clean up the back end a lot.
Bad arse LJ VirtualRussel I've been contemplating removing my spare also.I absolutely love the Savvy LED taillights. Spare or not I think they clean up the back end a lot.
