oooooh ok that was my guess. Will a factory soft top work on the bestop supertop hardware? Also what is all missing? I know the door surrounds and now I guess that little part that latches onto the door surround as well as the back bar. Anything else from what you can see? Also how does the header bar latch onto the top of the windshield? Sorry about all the questions haha i just have only had a hardtop and have no idea how soft tops work exactly.This is a Bestop Supertop. I love it. Its simple and super quick. Yes you have it backwards.
Looks like your missing a few parts.
Maybe the front channel as well? (that the plastic edge of the top fits into)
1. This little part that the door surround latches into.
2. This bar in the back:
wow ok I see that thank you so much i'll make sure to fix that carefully lolBe careful. This tab is bent, its used to hold the top tight. You will need to bend it back (kind of forward, so it fits in the little holes) But if you bend it too much and it breaks, its useless.
ok thanksIt looks like you have the frame mounted backwards. The narrow bars go over the door. The brackets in the back hold the bar at the bottom of the rear window. I had a similar frame on my YJ.
ok thanks a bunch for your help1. No OEM or ANY other brand of soft top will work with that hardware. Only, the Bestop Super Top: Link to the Skin on Amazon The top you have in your front seat will not work.
To make that frame work you will need:
Tailgate Bar
Windshield Brackets (I don't think you can buy these)
Also, maybe this
Here are the install instructions
I didn't care for the one I had on my YJ. The door surrounds seemed flimsy and were easily bent. The OEM frame on my TJ is much more robust.
That's what I do miss about the Super Top. I find the OEM top is easiest with two people, while the Besttop could be handled by myself with no problem. It takes me and my son less than 10 minutes to convert the OEM though, so I don't complain.This is great feedback. Thank you. How long does it usually take to remove the door surrounds? I have only had this Supertop, and my top goes up and down on a almost daily basis. I liked the thought of no surrounds... but I have no experience with OEM.
I think I can convert to no top / no doors / mirrors in about 12 minutes.
