Gearing question
AndyG
Because some other guys are perverts
Lifetime Supporting Member
Alabama
Why does my buddy's 97 Auto Sahara with verified 3:55 gears and 33" tires feel as strong as my 03 Rubi 5 speed with 4:56 and my 06 Rubi Automatic with 4:88. His tires are mildy aggressive A/Ts.
As big a fan if regearing as I am, I can't convince him in good conscious to regear this vehicle.
He actually put bigger tires on it to keep it from running such high RPMs... And it feels just right on the highway. Turns +-2500 at 65 mph.
Thanks
Andy G
Thanks
Andy G
Different transmission with different ratios - no OD
It seems if someone regeared this particular Jeep it would just scream anywhere over 60. ... With these 33 inch tires.
Just based on our collective knowledge what do we see guys doing with this particular transmission and 33 inch tires?
Reactions: Rick Flair
Damn. My friend got a free liberty and with a small lift and good tires it’s not horrible for snow runs!
I’ve got one, not bad at all when cooled and geared properly, the problem arises from minimal R&D leading to the use of stupid low gearing in order to correct the OD - that’s why most are shocked to hear the 5.38 recommendation for 35s and highway use.
Well .. I’ve just read so much on here.. @Jerry Bransford has said many times that 33” tires need 4:88 gears and that seemed to be the census. So I figured I must be geared to high with 3:55 but I got bigger tires in order to offset redlining at highway speed. Didn’t know the tranny had a lot to do with it
I need to check yours out. 😊
Reactions: Hog
Yeah that’s the reason. The “what gears should I run” chart shows the crazy differences between each trans and the needed gears.
The most you’re looking at is 4.10 - but that is the lowest you’d want to go.
