Wildman
Over Analyzer Extraordinaire & Attention Whore
Staff Member
@Chris if you decide to buy one of these blasting cabinets talk to me before you assemble it. I have some tips. And the dust reclaimer does work fairly well. But it isn't a bolt in item for the 40lb cabinet.
I imagine that's a nice thing to have, huh? I think about how often I would use one of those, and it starts to make sense. It makes cleaning stuff up so much easier.
Think about how much time you'd spend with a wire wheel and wire brush trying to clean something like this.
Maybe its your picture, but after an hour, I'd think they would have a MUCH more consistent surface finish. I have a small Trinco blaster and it gives me a nice, consistent finish...Here is about 1 hour of bead blasting.
Before I blasted the spring pads.
Here is after. I think I need a little more abrasive media. But they are a lot better.
Now I've got to primer them with weld thru paint. Then measure 3 times and tack once...![]()
Then I can move on to figuring out my ride height and start measuring...
Lots and lots of numbers...makes my head hurt
as an example...
Here are the befores
Some motorhome parts ( I don't have before's of these)
I have 50# of media loaded and I run about 90-95 psi. I have monkeyed around with the pick up to make sure my suction tube is correct. My blaster cabinet is so small, the media will pile up on one side and I get inconsistent delivery. But those two buckets wouldn't have taken me more than a half hour. I also use coal slag on rusty or painted steel. It breaks down pretty quick but its aggressive and CHEAP. Gives a nice surface for paint to grab too and one its painted, you can't tell (I.e. the paint fills in the surface texture).
Than either build conservatively, plan on using limit straps, or you're going to have to come back to it.
It's easier if you pick a belly height, wheelbase, and tire size now and you can mock things in (clamps, jacks, string, tape), move toward roughing things in (clamps and little tacks), finalize placement (good tack welds), and then do a final burn on everything.
Are you able to get the up travel you want at that frame height? If so, how much are you targeting?
From there (worrying about driveshaft angle later), since you want 12" shocks, do your airbags/coils have enough length to drop whatever is remaining of that 12"? If so, all you have left is figuring out if the driveshaft binds at that angle.
Are you shooting for level, or do you want some rake? If you want some rake, set the jack stands up to reflect that.
There are 6 crossmembers back there. Which one specifically are you referring to?But I do have a issue
At full stuff the upper arm mounts are hitting the crossmember at 10" of up travel. So I may have to notch it to all the axle more up travel.
Figure out why we cut the frame and move the wheel arch back yet?The one that the fuel tank would bolt to.
